A new beta switch firmware version is available. Firmware MS 16.2.1 was just released on 2023-07-08 and has been in this firmware category since 2023-07-07.
MS420 devices configured for this version will run MS 15.21.1
General features
ACL hit counter
DHCPv6 and IPv6 RA guard
Local Status Page Packet Capture
Ms12x features
DAI support
General fixes
Devices may be provided incorrect firmware download URLs resulting in firmware images failing to be downloaded and devices remaining on prior release (present since MS 16.2)
General known issues
Connecting a stacking cable to a stack that is online may result in a stack member going offline (present since MS 12)
Critical Authentication may incorrectly keep RADIUS server status as unreachable after a failed connection resulting in all subsequent authentication attempts failing (always present)
In rare instances, the port status will fail to update to dashboard until the system reboots (present since MS 14)
Switches move LACP ports to an active forwarding state if configured. This can cause loops when connecting to an MS390 or other Catalyst switches unless the bundles are configured on the MS390/Catalyst switches first. All non-catalyst ports are configured in passive LACP mode so that loops do not occur between Meraki switches (always present)
Ms120 known issues
Switches in extremely rare instances will experience reboots every few minutes (present since MS 11)
Switches may fail to provide PoE power to legacy access points (always present)
Ms125 known issues
The local status page cannot be accessed from the management port (always present)
Ms12x known issues
Ports with an odd-numbered MTU value fail to initialize (predates MS 11)
Ms210 known issues
Stack ports have an orange LED instead of green (present since MS 11)
Ms2xx/35x/4xx known issues
End devices connected at 100Mbps may fail to re-establish a link after the cable test has been run on the port (present since MS 14)
IPv6 multicast packets tagged for a VLAN may not be filtered correctly resulting in packets egressing into other VLANs (present since MS 14)
IPv6 solicited-node packets bypass port isolation (present since MS 14)
Rebooting a stack member may result in internal stacking packets to be sent out into the LAN (present since MS 15)
Switch stacks will learn MAC addresses from ports in the STP blocking state which can trigger a constant flood of MAC flaps in the event log
Ms355 known issues
In rare instances, stack ports fail to initialize after an upgrade (always present)
Ms35x known issues
Enabling Combined Power results in events being logged once per minute (present since MS 11)
UPoE does not negotiate over LLDP correctly (always present)
mGig switches will have an amber light for all physical ports that do not negotiate to the highest supported speed. Dashboard will continue showing a light green status for all ports above 100Mbps. For example, MS355 switch ports will incorrectly show an amber light for 1G, 2.5G, and 5G, but will show a green light for 10G.
Ms425 known issues
Large number of SNMP walks to switches in H.A. may destabilize the VRRP connection resulting in flapping (present since MS 15)
Stacks in rare instances will start dropping DHCP traffic on trusted ports while DAI is enabled until rebooted (present since MS 12)
Ms4xx known issues
When an SFP module is inserted/removed, BPDUs can be delayed leading to STP transitions in the network (predates MS 12)
To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
