A new beta cellularGateway firmware is now available on Tue, 14 Mar 2023
FirmwareBot
A new beta cellularGateway firmware version is available. Firmware MG 3.100 was just released on 2023-03-13 and has been in this firmware category since 2023-03-14.
1 Comment
Cellular gateway firmware versions MG 3.100 changelog
Important notice
  • While Meraki appliances have traditionally relied on UDP port 7351 for cloud communication and TCP ports 80 and 443 for backup communications, with MG 3.0 we are beginning a transition to using TCP port 443 as the primary means for cloud connectivity. In order to ensure proper connectivity to the Meraki cloud after this upgrade, please ensure that all “Meraki cloud communication” traffic specified in the Help > Firewall Info page is allowed through any firewalls or security filtering devices that may be deployed upstream of your Meraki appliances. These requirements have been updated on Nov 2022, so it’s important that you review them.
New feature highlights
  • IPv6 support for MG21/41
  • IP Passthrough support for MG41
Bug fixes
  • Improved NAT mode throughput for MG41
  • Improved cellular modem management and SIM detection
  • Corrected issue where some MGs may show the wrong connection type
Known issues
  • This build is currently only expected to run on MG21/41
  • There is an increased risk of encountering device stability and performance issues on all platforms and across all configurations for firmware set as beta
