A new beta cellularGateway firmware version is available. Firmware MG 3.0 was just released on 2023-03-10 and has been in this firmware category since 2023-03-13.
While Meraki appliances have traditionally relied on UDP port 7351 for cloud communication and TCP ports 80 and 443 for backup communications, with MG 3.0 we are beginning a transition to using TCP port 443 as the primary means for cloud connectivity. In order to ensure proper connectivity to the Meraki cloud after this upgrade, please ensure that all “Meraki cloud communication” traffic specified in the Help > Firewall Info page is allowed through any firewalls or security filtering devices that may be deployed upstream of your Meraki appliances. These requirements have been updated on Nov 2022, so it’s important that you review them.
New product highlights
MG51 support
New feature highlights
IPv6 support for MG21/41/51
IP Passthrough support for MG41/51
Bug fixes
Improved NAT mode throughput for MG41
Improved cellular modem management and SIM detection
Corrected issue where some MGs may show the wrong connection type
Known issues
There is an increased risk of encountering device stability and performance issues on all platforms and across all configurations for firmware set as beta
To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
