Documentation typos
CN_again
Documentation typos
Just calling out some of the smallest nitpicking typos.
802.1x or 802.1X – That is the question! Hint, the answer is 802.1X.
Access Manager non-802.1X Supported IoT or Other Endpoints - MAC Authentication Bypass (MAB) and iPS...has three lowercase x.
MR RADIUS Troubleshooting has one lowercase x.
Then small correction for SSID Naming Conventions
"SSID name may be any alphanumeric, case-sensitive text entry from two up to 32 characters." Characters should be changed to bytes. Since emojis are supported in the SSID, you can have one emoji that is two characters and eight bytes.
🇹🇭ไหว้ไฟ byte count
is 8 characters and 26 bytes. If it was just a little longer it would be invalid but this combo is working perfectly. (Translated from Thai it means "worship the fire" but when spoken aloud it sounds like Wi-Fi)
2 Replies 2
Good to know.  I have been writing 802.1X wrong in documents for decades.
It is easy for "English" speakers to overlook unicode, but unicode should be supported as a first class citizen.
BrandonD
Hi @CN_again,
Apologies for the delay here, but I have made the proper adjustments to the 802.1X references below per your recommendation:
Thanks for bringing this to our attention :).
