'Group Policy applied to a client VPN user is associated with the username and not the device. Different devices that connect to client VPN with the same username will receive the same group policy."
Can we add the part that explains that this is only true if we are tracking by mac. When tracking by mac, the "MAC" seen in the client page is a hash of the username and that is what allows the GP to be applied to a specific username.
When tracking by IP, that ability is lost - and unfortunately, it looks like there is no way to make a fixed association between username and IP.
When you assign a policy group to a client VPN, it looks like it is associated to a username but is not because if you connect from anohter computer using the same credentials, this new connection skip the policies applyed previuosly.
Looks like there is no way to apply group policies to usernames, only computers/phones/tables.
Is possible to use the same IP Addressing of one internal LAN interface? This avoid problem about Enterprise internal routing and permit to use the same policy already installed.
It is not possible to do this. When trying, meraki will throw an error. For VPN clients, you must assign a different segment than the one already configured for the LAN.
What is the point of using AD for VPN clients, otherwise it does not allow me to use the security policies applied to each group? This is a security bug, that any VPN user can access the content of the entire network. There is no way to apply restrictions for VPN clients? What does @Meraki say about all this?
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b0181ba098073","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b0181ba098073_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b0181ba098073_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b0181ba098073_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_3b0181b2a1f2ca","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
