Feb 23 2024
8:52 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Feb 23 2024
8:52 AM
Correction in the document about DHCP option
As some can see, there is an open discussion about the Option configuration in the DHCP server configurations of the MS Switches.
Basically, support informs that it is not possible to configure the MS390 and Catalyst 9300 models.
However, this is not mentioned anywhere in the documentation, so this information needs to be added.
1 Reply 1
Oct 2 2024
4:08 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Oct 2 2024
4:08 PM
Hello @alemabrahao,
Thank you for providing this information.
There are some DHCP option limitations regarding the MS390 and Catalyst 9300 models. Since this initial post, the unsupported DHCP options have been updated in the Setting Custom DHCP Options documentation under the section 'Unsupported DHCP options on MS390 and Meraki-managed C9300'.
Please let me know if this addition to the documentation is acceptable and helps to address the matter.
Best,
Feli
If you found this post helpful, please give it kudos. If this answer helped solve the issue, click "accept as solution" so that others can benefit from it.
