return specified fields only with api call
blshaw32
For example:  I'm trying to get just the Organization name:
https://api.meraki.com/api/v1/organizations/{organizationId}?fields=name
Or find out the organizationId for a company called "CompanyName"
https://api.meraki.com/api/v1/organizations/{organizationId}?fields=id&name="CompanyName"
I have tried many different variations of the above, and search in the forums to no avail.
Other API's I've worked with have a way to pass conditions into the request and only get back the single field you need.  That would sure save a bunch of parsing when the payload returns to my console.
Thaks in advance for the help.
Natively (if I'm not mistaken) you won't be able to do it this way. Today, to extract the information the way I need it, I am using the following code.
import requests
import json
# Make the API request
response = requests.get('https://api.meraki.com/api/v1/organizations/{organizationId}')
# Convert the response to JSON
data = response.json()
# Extract the field you need
org_name = data['name']
I hope it helps.
sungod
The current API returns what it likes, for a given API call it can also vary depending on context. There's no way to limit which field(s) are returned.
blshaw32
Thank you for the quick responses.  I had hoped I was just missing something, 😉
I will carry on parsing and extracting.
Have a great day!
Here is an example in Python of getting an org and network ID by searching on the name using the Meraki Python SDK.
# This function retrieves the netId
def getNetId(orgName,netName):
	orgId=None
	netId=None
	# Search for the org
	for org in dashboard.organizations.getOrganizations():
		if org['name'] == orgName:
			orgId=org['id']
			break;
	if orgId == None:
		print("Invalid organization name supplied: "+orgName)
		exit(-1)
	# Search for the network
	for net in dashboard.organizations.getOrganizationNetworks(orgId):
		if net['name'] == netName:
			netId=net['id']
			break;
	# If no network, search for a template
	if netId == None:
		for net in dashboard.organizations.getOrganizationConfigTemplates(orgId):
				netId=net['id']
				break;
	# Nothing found matching at all
	if netId == None:
		print("Invalid network name supplied: "+netName)
		exit(-1)
	return netId
