i am looking for an api that returns bgp peers info for a given appliance serial
CiscoLumen
 /networks/{networkId}/appliance/vpn/bgp
this will return the peers info for the remoteAS etc bu it works at netwotk level not an appliance level
Also i get a message always on our networkIDs from Lumen SDWAN Meraki saying the below.
AP call: https://api.meraki.com/api/v1/networks/L_604608249974502458/appliance/vpn/bgp
      "errors": [
            "Unsupported for networks without passthrough mode enabled"
can some one help  me on the specifics of network configs needed in order to return us the bgp prring info on meraki
There is no API for It as you can see at this link.
https://developer.cisco.com/meraki/api-v1/get-network-appliance-vpn-bgp/
CiscoLumen
is there an API to determine which networks are enabled wih BGP?
BGP is only supported when the MX is in passthrough mode. This can be set onAddressing & VLANspage.
Did you check the available APIs in the link sent?
If you can't find it there, it means you don't have it.
