how to retrive Rx and Tx values for a wan1 or wan2 interface on he meraki appliance
CiscoLumen
I have been trying out the uplinkbandwidth api to fech he limits to send and receive on a nework ID bu for an appliance on a particular interface how to pull the live Rx and Tx bandwidtgh values thru dashboard apis as we see on the meraki dashboard monitor UI?
CiscoLumen
yes that api works and returns all appliances under the network ID under that Org ID ,but hat api lists thousands of srials and i cant filter a query by serial[]=serialNumber of a particular appliance
RaphaelL
Hi ,
I think that this is the endpoint to achieve what you are trying to do : https://developer.cisco.com/meraki/api-v1/get-organization-appliance-uplinks-usage-by-network/
CiscoLumen
Yes that api works and returns all appliances under the network ID under that Org ID ,but hat api lists thousands of srials and i cant filter a query by serial[]=serialNumber of a particular appliance : example :
            "networkId""L_604608249974502433",
            "name""3-XWP7ZJ3HFT_SL0003094289_A_535_US_HIGHW_CAMDE_MO",
            "byUplink": [
                        "serial""Q2MY-QCNY-4KXM",
                        "interface""cellular",
                        "sent"0,
                        "received"0
                        "sent"3276,
                        "received"543039
                        "interface""wan1",
                        "sent"227483202,
                        "received"467247496
            "networkId""L_604608249974502436",
            "name""3-XWP7ZJ3HFT_SL0003094300_A_103_PIN_OAK_AUROR_MO",
            "byUplink": [
                        "serial""Q2MY-MGFC-8UVV",
                        "sent"0,
                        "received"0
                        "sent"3276,
                        "received"556038
                        "interface""wan1",
                        "sent"168634567,
                        "received"197305274
            "networkId""L_604608249974502441",
            "name""3-XWP7ZJ3HFT_SL0003094290_A_100_4TH_ELDON_MO",
            "byUplink": [
                        "serial""Q2MY-TU4B-R9FH",
                        "sent"0,
                        "received"0
                        "sent"3276,
                        "received"534821
                        "interface""wan1",
                        "sent"130885033,
                        "received"182404000
            "networkId""L_604608249974502442",
            "name""3-XWP7ZJ3HFT_SL0003094306_A_19618_STEVEN_BOONV_MO",
            "byUplink": [
                        "serial""Q2MY-NV62-N846",
                        "sent"0,
                        "received"0
                        "sent"3419,
                        "received"544253
                        "interface""wan1",
                        "sent"268493819,
                        "received"676196344
            "networkId""L_604608249974502444",
            "name""3-XWP7ZJ3HFT_SL0003094291_A_1515_THOMPSO_SEDAL_MO",
            "byUplink": [
                        "serial""Q2MY-BQPY-P8TU",
                        "sent"3741,
                        "received"534237
                        "interface""wan1",
                        "sent"223811663,
                        "received"350172198
            "networkId""L_604608249974502445",
            "name""3-XWP7ZJ3HFT_SL0003094311_A_2600_BROADWA_SEDAL_MO",
            "byUplink": [
                        "serial""Q2MY-QCA9-T9W8",
                        "sent"0,
                        "received"0
                        "sent"3276,
                        "received"545905
                        "interface""wan1",
                        "sent"98248955,
                        "received"103790380
            "networkId""L_604608249974502446",
            "name""3-XWP7ZJ3HFT_SL0003094296_A_204_HIGHWAY__CENTR_MO",
            "byUplink": [
                        "serial""Q2MY-JUGH-YW26",
                        "sent"0,
                        "received"0
                        "sent"3276,
                        "received"529510
                        "interface""wan1",
                        "sent"265000275,
                        "received"660152330
            "networkId""L_604608249974502448",
            "name""3-XWP7ZJ3HFT_SL0003094294_A_4021_LARK_BATTL_MO",
            "byUplink": [
                        "serial""Q2MY-LYMS-D7Z3",
                        "sent"0,
                        "received"0
                        "sent"3403,
                        "received"540888
                        "interface""wan1",
                        "sent"188263689,
                        "received"296030385
            "networkId""L_604608249974502449",
            "name""3-XWP7ZJ3HFT_SL0003094287_A_5940_OSAGE_B_OSAGE_MO",
            "byUplink": [
                        "serial""Q2MY-RDD9-6VDP",
                        "sent"0,
                        "received"0
                        "sent"3363,
                        "received"546658
                        "interface""wan1",
                        "sent"204009183,
                        "received"879311703
            "networkId""L_604608249974502451",
            "name""3-XWP7ZJ3HFT_SL0003094295_A_5384_CAMPBEL_SPRIN_MO",
            "byUplink": [
                        "serial""Q2MY-689B-BNA2",
                        "sent"0,
                        "received"0
                        "sent"3276,
                        "received"561123
                        "interface""wan1",
                        "sent"270191750,
                        "received"1262911049
            "networkId""L_604608249974502452",
            "name""3-XWP7ZJ3HFT_SL0003094285_A_301_8TH_ELDON_MO",
            "byUplink": [
                        "serial""Q2MY-57EW-WF7N",
                        "sent"0,
                        "received"0
                        "interface""wan1",
                        "sent"57578192,
                        "received"52221202
            "networkId""L_604608249974502454",
            "name""3-XWP7ZJ3HFT_SL0003094309_A_26695_COUNTY_EDGAR_MO",
            "byUplink": [
                        "serial""Q2MY-54GR-YLWA",
                        "sent"3276,
                        "received"559205
                        "interface""wan1",
                        "sent"71184634,
                        "received"113289656
            "networkId""L_604608249974502458",
            "name""3-XWP7ZJ3HFT_SL0003094302_A_5995_OSAGE_B_OSAGE_MO",
            "byUplink": [
                        "serial""Q2MY-2REP-FS77",
                        "sent"0,
                        "received"0
                        "sent"3276,
                        "received"568594
                        "interface""wan1",
                        "sent"238720563,
                        "received"363258997
CiscoLumen
