getNetworkApplianceFirewallL3FirewallRules | OBJ(766174886606406852)
AhmedJawad
Hi All,
  I'm getting OBJ(766174886606406852) as a result of the source IP address of a rule from the MX firewall. The source in the first place is an object from a security config template
The template has 100+ networks bound to it.
example
policy : allow , protocol Any source HR subnet "  Vlan 6 : 10.10.10.0/24" , destination 10.10.100.0/24
I notices some sources not all of them getting OBJ(766174886606406852)
other sources are retrieving the Vlan only not the subnet with it
is there is a way i can have the name of the object " HR subnet" and the vlan with the subnet in the result?
Thank you!
1 Reply 1
sungod
