Is that what you are looking for ?
RestAPI response code and status
Code | Status | Description |
200 | OK | The request was successfully completed. |
201 | Created | A new resource was successfully created. |
400 | Bad Request | The request was invalid. |
401 | Unauthorized | The request did not include an authentication token or the authentication token was expired. |
403 | Forbidden | The client did not have permission to access the requested resource. |
404 | Not Found | The requested resource was not found. |
405 | Method Not Allowed | The HTTP method in the request was not supported by the resource. For example, the DELETE method cannot be used with the Agent API. |
409 | Conflict | The request could not be completed due to a conflict. For example, POST ContentStore Folder API cannot complete if the given file or folder name already exists in the parent location. |
500 | Internal Server Error | The request was not completed due to an internal error on the server side. |
503 | Service Unavailable | The server was unavailable. |
Regards/Inder
www.thenetworkdna.com
