from meraki import meraki
I installed python (and Pycharm) on 3 different devices but did managed to get meraki lib working.
I did:
  • python installation
  • pip installation
  • pip upgrade to 20.0.2
  • pip install meraki (and upgrade)
  • pip install meraki-sdk (and upgrade)
python <enter>
# from meraki import meraki
(see attachment)
I also checked the site-package folder and see both lib's available in folder
What is the magic?
8 REPLIES 8
Re: from meraki import meraki
Hi Rob,
A couple of things:
Good luck!
Thanks for the quick reply, but...
when using import statement I get an error message:
Spoiler
ModuleNotFoundError: No module named 'meraki'
C:\WINDOWS\system32>pip3 list
Package Version
CacheControl 0.12.6
certifi 2019.11.28
chardet 3.0.4
idna 2.9
jsonpickle 0.9.6
meraki 0.90.2
msgpack 1.0.0
pip 20.0.2
python-dateutil 2.8.1
requests 2.23.0
setuptools 41.2.0
six 1.14.0
urllib3 1.25.8
What's the output when you execute the following command in the python interactive prompt:
help("modules")
help("modules")help("modules")
That's strange. It says it can't import a module named meraki, however if you ask it to list the modules it does have, it shows the module. Does not compute.
What does your windows PATH environment variable look like?
echo %PATH%
do not need to import from, just
import meraki
developer.cisco.com/meraki/whats-new/#2020/01-2020
