dashboard.switch.createNetworkSwitchAccessPolicy doesn't seem to be working properly from Python
shngrhm27
I'm trying to create a new access policy with a Python script using the Meraki library.
I'm 'getting' the model policy from a known good network switch, & trying to 'put' it on a few more network switches.
access_policy = dashboard.switch.getNetworkSwitchAccessPolicies(network_id)
ap_name = access_policy[0]["name"]
radiusServers = access_policy[0]["radiusServers"]
dict_radiusServers = radiusServers[0]
pop_radiusServers = dict_radiusServers.pop('serverId')
radiusServers = [dict_radiusServers]
radiusTestingEnabled = access_policy[0]["radiusTestingEnabled"]
radiusCoaSupportEnabled = access_policy[0]["radiusCoaSupportEnabled"]
radiusAccountingEnabled = access_policy[0]["radiusAccountingEnabled"]
hostMode = access_policy[0]["hostMode"]
urlRedirectWalledGardenEnabled = access_policy[0]["urlRedirectWalledGardenEnabled"]
radius = access_policy[0]["radius"]
guestPortBouncing = access_policy[0]["guestPortBouncing"]
radiusAccountingServers = access_policy[0]["radiusAccountingServers"]
dict_radiusAccountingServers = radiusAccountingServers[0]
pop_radiusAccountingServers = dict_radiusAccountingServers.pop('serverId')
radiusAccountingServers = [dict_radiusAccountingServers]
radiusGroupAttribute = access_policy[0]["radiusGroupAttribute"]
accessPolicyType = access_policy[0]["accessPolicyType"]
increaseAccessSpeed = access_policy[0]["increaseAccessSpeed"]
guestVlanId = access_policy[0]["guestVlanId"]
dot1x = access_policy[0]["dot1x"]
voiceVlanClients = access_policy[0]["voiceVlanClients"]
urlRedirectWalledGardenRanges = access_policy[0]["urlRedirectWalledGardenRanges"]
response = dashboard.switch.createNetworkSwitchAccessPolicy(network_id, ap_name, radiusServers, radiusTestingEnabled, radiusCoaSupportEnabled, radiusAccountingEnabled, hostMode, urlRedirectWalledGardenEnabled,
radius,
guestPortBouncing,
radiusAccountingServers,
radiusGroupAttribute,
accessPolicyType,
increaseAccessSpeed,
guestVlanId,
dot1x,
voiceVlanClients,
urlRedirectWalledGardenRanges)
Here's a printout of all those variables:
L_599541700393704277
LHC-NAC-802.1X-Wired
[{'organizationRadiusServerId': '3797660385780170753', 'host': '10.0.19.148', 'port': 1812}]
True
True
True
Multi-Domain
True
{'criticalAuth': {'dataVlanId': 100, 'voiceVlanId': 10, 'suspendPortBounce': False}, 'failedAuthVlanId': 100, 'reAuthenticationInterval': 86400}
True
[{'organizationRadiusServerId': '3797660385780170753', 'host': '10.0.19.148', 'port': 1813}]
11
Hybrid authentication
True
100
{'controlDirection': 'both'}
True
['10.0.0.0/8']
I'm getting an error message:
radius,
...<7 lines>...
voiceVlanClients,
TypeError: Switch.createNetworkSwitchAccessPolicy() takes 9 positional arguments but 19 were given
I was able to create a policy using the Meraki Developer Hub Dashboard API, only after enabling the 'walledgarden' & adding a subnet.
Any ideas on what I'm doing wrong?
1 Reply 1
nan3540
You have given all you arguments as positional arguments to the function
but the function expects only some of the arguments as positional, the rest should be keyword arguments, like in the below function call
    network_id, name, radius_servers, radius_testing_enabled, radius_coa_support_enabled, radius_accounting_enabled, host_mode, url_redirect_walled_garden_enabled,
    radius={'criticalAuth': {'dataVlanId': 100, 'voiceVlanId': 100, 'suspendPortBounce': True}, 'failedAuthVlanId': 100, 'reAuthenticationInterval': 120, 'cache': {'enabled': False, 'timeout': 24}},
    guestPortBouncing=False,
    radiusAccountingServers=[{'organizationRadiusServerId': '42', 'host': '1.2.3.4', 'port': 22, 'secret': 'secret'}],
    radiusGroupAttribute='11',
    accessPolicyType='Hybrid authentication',
    increaseAccessSpeed=False,
    guestVlanId=100,
    dot1x={'controlDirection': 'inbound'},
    voiceVlanClients=True,
    urlRedirectWalledGardenRanges=['192.168.1.0/24']
you can read more about arguments to functions in below article
https://profound.academy/python-mid/positional-and-keyword-arguments-5LvKxDSUICCBH7Z96b1n
