There is a documentation error with:
https://developer.cisco.com/meraki/api-v1/#!create-network-wireless-ssid-identity-psk
It doesn't define the parameter "Number", and the example shows it being set to "". This won't work. number appears to be the SSID number, and needs to be an integer.
