beginer for API
Scott_CC
beginer for API
Hello
Good day to you.
I am beginner for Meraki API, and plan to use Python with Meraki library.
May you please help me below question.
1.  I would like have SSID report for whole Org.  Which API could query working SSID on Org or Network or AP?
2. If I would like update AP, MX, switch settings, all is process by "dashboard.devices.updateDevice"?
3. When I update device with "dashboard.devices.updateDevice", I need a property list. But when can I find it?
group the question, my daily task is update switch port, management IP, change SSID settings. I haven't found these API.
Thanks for your time.
Best Regards.
Scott Gao
5 Replies 5
Scott_CC
Hello
To Meraki engineer,
I see Network or Org process is call by ID. Do you think allow call by name is friendly?
Thank you.
sungod
You need to call by ID not name.
sungod
1 I suggest https://developer.cisco.com/meraki/api-v1/get-organization-wireless-ssids-statuses-by-device/
2 there are many different calls to update different things
3 on an existing device you can use https://developer.cisco.com/meraki/api-v1/get-device/ to get the current settings, for a new device you need to create the settings yourself
I strongly recommend read through the complete API guide, starting at https://developer.cisco.com/meraki/api-v1/introduction/
Then at least review all the API calls to get an idea of what is there, also you can use the search to find calls containing a keyword you are interested in, like SSID for instance...
https://developer.cisco.com/meraki/api-v1/search/?q=ssid
As you will be using the Python library, I would begin making some scripts to gather/format the data you are interested in, to get a feel for how things work.
Scott_CC
Hello sungod
Thanks for your reply.
I read all link you suggest. I still can not find out API to update switch and AP LAN IP. Do you mind provide exact link?
Thank you.
Scott_CC
