- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Wireless Overview - Access Data via API / python sdk
Hello developers,
is there a way to collect the access points wireless overview data dashboards?
e.g.
We would like to extract this information on a regular basis (for reports and monitoring).
I was not able to find either a direct way via api or sdk or a manual way (e.g. the clients time to connect data) yet...
Regards
Michael
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I managed to collect the data via single calls and rebuilded the logic in python
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I'm not aware of any way to collect this summarised data. To build this yourself from the raw data from be pretty hard.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @AsterV4 - yes of course - not the full code but an approach if this is fine for you.
As @PhilipDAth already mentioned its quite difficult to reproduce everything but i extracted the neccessary parts for me...
You need to build a request with
and for example to get the signal quality you need to do something like:
"GET",
"<base_url>/manage/wireless_insights_network/signal_quality_by_client?timespan=86400",
The dash_auth cookie can be seen in your own calls against the website when browsing - just take a look at the developer tools of your browsersession.
I´m aware that this "solution" will probably be not that stable, because of frontend or backend changes and the refreshing of the dash_auth cookie is also not that handy - but since there is no other current solution this is working much faster than manually searching for the "problematic" networks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
