Wireless Client Health Scores = b''
AidanVenn
Running
VisStudio 1.77.3 on windows 11
Meraki Library version 1.32.1
Python 3.10
Meraki AP: MR36
Firmware 17.10.4
I am attempting to run - https://developer.cisco.com/meraki/api-v1/#!get-network-wireless-clients-health-scores
This gives back wireless clients health scores
The code is below:
url = "https://api.meraki.com/api/v1/networks/XXXXXXX/wireless/clients/healthScores"
payload = None
headers = {
"Content-Type": "application/json",
"Accept": "application/json",
"X-Cisco-Meraki-API-Key": API_KEY
response = requests.request('GET', url, headers=headers, data = payload)
print(response.text.encode('utf8'))
However I get the output of:
b'' - in visStudio
and Error 404 Not Found in the developer hub test environment.
The API and network appear to work fine on other scripts.
Any ideas what's wrong?
Many Thanks
Aidan
sungod
This is an Early Access API call, have you enabled EA on the organization?
I suspect not, which would explain the 404.
See...
https://developer.cisco.com/meraki/api-v1/#!api-reference-early-access-overview
We need @sungod for this one ...
If you are using the Meraki library - why are you using requests directly?
RaphaelL
I will check the results on my end.
On a side note , you have included a firmware ( MX ) that has no influence on your issues. What MR firmware are you running ?
Good point! MR fw is 29.5.1 - latest and greatest...
sungod
See...
