I wrote a small script which will generate QRCodes for configured SSIDs. The script is using asyncio and api version 1.
usage: generate_qrcodes.py [-h] [-o ORGANIZATION] [-n NETWORKS [NETWORKS ...]]
[-s SSIDS [SSIDS ...]]
Generates QRCodes from Meraki wireless networks
optional arguments:
-h, --help show this help message and exit
-o ORGANIZATION, --organization ORGANIZATION
the name/id of the organization
-n NETWORKS [NETWORKS ...], --network NETWORKS [NETWORKS ...]
the name/id of the networks to generate the qr codes
from. If you are providing this parameter, then you must
provide the organization.
-s SSIDS [SSIDS ...], --ssid SSIDS [SSIDS ...]
the name of the ssids to generate the qr codes
You have to provide at least the organization or network parameter.
the QRCodes will be places in a subdirectory "img". The Filename is {NetworkName}_{SSID}.png.
Example:
Very cool!
I am interested in trying this out. Do you know if this script is still valid. ....
yes it is still working fine. There is a deprecation warning, which can be ignored at the moment.
Just to confirm, this will let me create a QR Code for a guest wifi access with a splash page? Also, I am getting a SSL: CERTIFICATE_VERIFY_FAILED on trying, and I guess I have to setup a certificate in addition to the API KEY. Do you know where I can find info on setting up a certificate for Meraki?
Thanks in advance for your help.
I was able to get this working, but I have a question on the user experience, as the QR codes are asking me to joint the guest wifi network, but it is not causing the splash page to come up. I can share a video if you want to see.
hello @Fantasticmrfox can you please share the video of how you were able to get the QR codes working?
Thanks!
Hi all.
I have a really good tip to create native QR codes without any third party link or script.
It is great because it reveals the true WiFi option when using your camera.
Apple must have released an update, as you couldn't scan the QR and it only worked on Android before, now it works on Apple iOS 17.
If you want your splash page, just configure that in Meraki.
Hope this helps
