- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Webhook shared secret with HTTP header
Hi, I'm using a webhook that supports shared secrets, but the secret needs to be passed in via a configured http header (which IMO is the superior way to do this vs including the secret in the payload). Is there a way to have the meraki webhook include the shared secret in a header? Optionally, configuring the header name would be nice, but as long as I can figure out what the header name is to provide it to the receiving webhook, that would be sufficient.
Thanks.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You can probably use the template tools to create the request in the form you need, see...
https://developer.cisco.com/meraki/webhooks/payload-templates-overview/
As an example, I've used it to put authentication info into the header for Splunk integration...
https://community.meraki.com/t5/Developers-APIs/Dashboard-Webhooks-to-Splunk/m-p/198696
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This did exactly what I wanted. Thanks!
