Webhook for WAN Public IP Change
AndP_net
Hello is there a way to create a Webhook Template when the Public IP of my MXs changes?
Thank you
Regards
5 Replies 5
I don't know if I understood correctly, but, yes, you can create a webhook to get alerts when the public IP of your MX changes.
Navigate to the Network-wide  > Alerts page.
When defining an HTTPS server to receive the webhook alert, you have an option to select a payload template.
Click on the ‘Add or edit webhook templates’ to begin. To create a new template, press the ‘Create template’ button.
The template must be written in a way that it renders to valid JSON RFC82591. You can use the ‘Generate Preview’ button to check for any JSON & Liquid syntax errors.
Webhooks support all configurable alert types available in the dashboard under Network-wide > Alerts. You can set the alert type to notify you when the public IP changes.
Webhooks - Cisco Meraki
Meraki webhooks and sample webhooks schemas. - Meraki Webhook API docs - Cisco Meraki Developer Hub
Hello Thank you for your quick reply but if i well understood there's no way to set up an allarm just for Public IP change as @PhilipDAth said.
I'm not aware of any alert for a change of IP address - which you need to generate a WebHook ...
Available alerts are:
You need to create a template.
Could you please more specific? I have looked this up and can't find a way to do it.
