Way to see organization wide network switches and APs that are online and their local LAN IP?
Phillip_Crow
Is there anyway to see the local LAN IP of your organization switches and APs in each network? I have tried the google sheets script but it only shows 1000 at a time. Any help is appreciated, thanks
RaphaelL
Hi ,
Easy with the APIs : https://developer.cisco.com/meraki/api-latest/get-organization-devices/
You will have to use pagination : The number of entries per page returned. Acceptable range is 3 - 1000. Default is 1000.
Might be easier to use the official python SDK
I don't know the answer, but I can tell you Google Bard is very good at writing Python scripts that use the Meraki API.
https://bard.google.com/
John_on_API
Meraki Employee All-Star
