Warning from Terraform when use cisco-open/meraki provider
Hugh-Nguyen
We have been using Terraform on Meraki using cisco-open provider. Recently, when I run terraform init, I got this warning
Warning: Additional provider information from registry
│ The remote registry returned warnings for registry.terraform.io/cisco-open/meraki:
│ - For users on Terraform 0.13 or greater, this provider has moved to CiscoDevNet/meraki. Please update your source in required_providers.
Does this mean we have to use the one from CiscoDevNet now? I can't find any information regarding this. the cisco-open one just got updated like 2 weeks ago. And look like Terraform for meraki by cisco-open is the official project whereas the one in CiscoDevNet is community driven and not being supported by Cisco.
Thank you
5 Replies 5
I thought I remembered seeing a post about this recently on this community, but I can't find it now.
I did find this.
https://community.meraki.com/t5/Developers-APIs/Now-in-beta-the-official-Terraform-provider-for-Mera...
Franco244
Yeah this is very confusing to determine which provider to use as both seem to be actively developed.
Oren
I missed this message before.
The official provider is the cisco-open one. I will check on Monday where did this message come from.
Franco244
For reference @Oren these are the two providers that are available. Both seem to be owned by Cisco/Meraki and being developed concurrently
https://github.com/cisco-open/terraform-provider-meraki
https://registry.terraform.io/providers/cisco-open/meraki/1.0.2-beta
When using the above module, we get the aforementioned error to use the other provider:
https://github.com/CiscoDevNet/terraform-provider-meraki
-- After reading details of the repo I see the following:
| Please note that this Terraform provider is developed and maintained by a dedicated community of
| contributors. It is not directly supported by Cisco. While we strive to ensure the provider is robust and
| reliable, its development relies on community contributions and engagement.
https://registry.terraform.io/providers/CiscoDevNet/meraki/0.1.7
Oren
Thanks, Franco. I’ll take care of the confusion.
Until further notice, Cisco-open is the provider developed and maintained by the Meraki BU.
