Using Cisco Meraki API to change Port States
SohamMaoor
Just browsing
Need to control the up/down state of multiple ports/switches on a Meraki network when certain email notifications arrive.
I believe I have the correct API call and tested with POSTMAN.
I now need to automate the process so when an email notification trigger arrives, it sends the code.
My coding skills are not great. Is there a SaaS or easy solution to achieve this?
0 Replies 0
