Use of OAuth 2.0 nonce parameter
RCocks
I've been implementing OAuth 2.0 flow for my demonstration QR code application.
I am confused about the optional "nonce" parameter.
I had anyway planned to add a temporary secret to the `state` which is OAuth2 standard, and to validate against this state to prevent CSRF and prevent replay attacks.
However, I have read the documentation at https://developer.cisco.com/meraki/api-v1/oauth-overview/#oauth-20  .
This mentions a parameter
nonce (optional)
This is interesting, and I assumed could be used for a similar purpose, but the documentation never refers to this parameter or its purpose again.
How is this `nonce` used in the flow?
It does not appear to be attached as a parameter to the callback, what purpose does it have otherwise please?
Oren
Meraki Employee All-Star
I literally wrote the document, and I have no recollection of adding “nonce” there. It’s mandatory for OIDC, but not for the way you’d interact with OAuth.
I’ll remove it from the documentation.
Thanks for flagging this!
5 Replies 5
I don't know the answer.
I have only used the OAUTH interface from Python.  This GitHub has an example.
https://github.com/obrigg/meraki-oauth
sungod
I've not used the Meraki Oath 2 service, but my guess is that the authorisation server simply doesn't have the feature implemented yet.
Presumably if/when it is added, the server would look for a nonce where required, and if it's not present return the nonce_required error and the nonce endpoint that client must use to obtain one.
Maybe someone from Meraki can comment?
RaphaelL
@Oren Sorry to tag you , but this seems like something you would be able to answer 😊
Oren
Oren
To close the loop on this, the documentation has been updated and the "nonce" reference has been removed.
