Update Template MX wireless settings and MR wireless password
Del_B
I'm trying to find a way using an API to update a Template's wireless setting under both the Security & SD-WAN->Wireless Settings and Wireless->SSID password(s).
I have one that updates the passwords for Wireless->SSID on the templates, but I don't see a way to also update the Security & SD-WAN->Wireless Settings in templates.
In a few months, we will be adding 1400+ Meraki sites, and most have MX68w and MX68cw.  Prefer not to add anymore templates
Meraki does not currently support updating the "Security & SD-WAN → Wireless Settings" section of a template via API.
7 Replies 7
Del_B
So best to add a section to find MX68w and update those individually?  If so, would the Template override it?
If they're in a template, you can't update the password individually, but you can update it through the template.
To update each one individually, you'd have to remove them from the template.
You can treat the TemplateId the same as a NetworkId.
This is some sample code that I use that allows a user to specify either a network name OR a template name.
def getNetId(orgId, netName):
    netId = None
    # Search for the network
    for net in dashboard.organizations.getOrganizationNetworks(orgId):
        if net['name'] == netName:
            netId = net['id']
            break
    # If no network, search for a template
    if netId is None:
        for net in dashboard.organizations.getOrganizationConfigTemplates(orgId):
                netId = net['id']
                break
    # Nothing found matching at all
    if netId is None:
        print("Invalid network name supplied: " + netName)
        exit(-1)
    return netId
You can then use APIs like these to get and update the security appliance's WiFi settings.
https://developer.cisco.com/meraki/api-v1/get-network-appliance-ssid/
https://developer.cisco.com/meraki/api-v1/update-network-appliance-ssid/
And will this really work? It seems like a hack. 🤣
Yes.  I would say nearly every large Meraki org I look after uses templates, and frequently the scripts I work on have to make changes to those templates.
@Del_B  I think you should accept @PhilipDAth's answer as the solution.
