Terraform Meraki MX L3 firewall rules order
MartinLL
Hi gang,
I'm working on a full IaC deployment of a Meraki organization using terraform.
I notice some issues with the firewall L3 rule ordering when applying the terraform code.
Since terraform applies all code at the same time unless a dependency is decleared the 10 or so starting rules i have end up in a random order. For the most part i dont care about rule order, but i got some deny rules that must be placed in a spesific sequence.
I notice that the API endpoint for L3 FW rules also does not contain any parameters for sequence.
Has anyone worked around this in a way that is scaleable?
Also if some meraki employees read this, is it possible to add a feature request for firewall sequence numbering?
Thanks in advance!
MLL
Oren
Meraki Employee All-Star
Can you kindly open an issue on our GitHub repo? Our developers will take a look.
11 Replies 11
You can try using a script (e.g., Python or Bash) that calls the Meraki API directly in the desired order. Terraform can trigger this script using the null_resource provisioner and local-exec.
Oren
Question. When using updateNetworkApplianceFirewallL3FirewallRules, the input is an array of rules.
Are you seeing different behavior between Terraform, Postman, Python, etc’?
If so, can you share the Terraform plan you’re using?
MartinLL
It is indeed an array.
This is the terraform resource for L3 firewall rules.
resource "meraki_networks_appliance_firewall_l3_firewall_rules" "sb3_fw_l3" {
  network_id = meraki_networks.sb3.id
  rules = [{
    comment        = "Deny-RFC1918."
    dest_cidr      = "10.0.0.0/8, 172.16.0.0/12, 192.168.0.0/16"
    dest_port      = "any"
    policy         = "deny"
    protocol       = "any"
    src_cidr       = "any"
    src_port       = "any"
    syslog_enabled = false
    comment        = "Allow-corp-outbound-to-internet."
    dest_cidr      = "any"
    dest_port      = "any"
    policy         = "allow"
    protocol       = "any"
    src_cidr       = var.subnet_prefix_corp
    src_port       = "any"
    comment        = "Allow-iot-outbound-to-internet."
    dest_cidr      = "any"
    dest_port      = "any"
    policy         = "allow"
    protocol       = "any"
    src_cidr       = var.subnet_prefix_iot
    src_port       = "any"
    comment        = "Allow-guest-outbound-to-internet."
    dest_cidr      = "any"
    dest_port      = "any"
    policy         = "allow"
    protocol       = "any"
    src_cidr       = var.subnet_prefix_guest
    src_port       = "any"
This is how it ends up in the Dashboard.
I deleted all rules above and pasted the same array into postman.
Postman body:
    "rules": [
            "policy": "deny",
            "protocol": "any",
            "srcCidr": "any",
            "destCidr": "10.0.0.0/8, 172.16.0.0/12, 192.168.0.0/16",
            "comment": "Deny-RFC1918.",
            "srcPort": "any",
            "destPort": "any",
            "syslogEnabled": false
            "policy": "allow",
            "protocol": "any",
            "srcCidr": "10.100.2.0/24",
            "destCidr": "any",
            "comment": "Allow-corp-outbound-to-internet.",
            "srcPort": "any",
            "destPort": "any",
            "policy": "allow",
            "protocol": "any",
            "srcCidr": "10.110.2.0/24",
            "destCidr": "any",
            "comment": "Allow-iot-outbound-to-internet.",
            "srcPort": "any",
            "destPort": "any",
            "policy": "allow",
            "protocol": "any",
            "srcCidr": "10.120.2.0/24",
            "destCidr": "any",
            "comment": "Allow-guest-outbound-to-internet.",
            "srcPort": "any",
            "destPort": "any",
Postman response:
200 OK
"rules": [
            "policy": "deny",
            "protocol": "any",
            "srcPort": "Any",
            "srcCidr": "Any",
            "destPort": "Any",
            "destCidr": "10.0.0.0/8,172.16.0.0/12,192.168.0.0/16",
            "policy": "allow",
            "protocol": "any",
            "srcPort": "Any",
            "destPort": "Any",
            "destCidr": "Any",
            "policy": "allow",
            "protocol": "any",
            "srcPort": "Any",
            "destPort": "Any",
            "destCidr": "Any",
            "policy": "allow",
            "protocol": "any",
            "srcPort": "Any",
            "destPort": "Any",
            "destCidr": "Any",
            "comment": "Default rule",
            "policy": "allow",
            "protocol": "Any",
            "srcPort": "Any",
            "srcCidr": "Any",
            "destPort": "Any",
            "destCidr": "Any",
Dashboard:
Everything is identical in the array. The only difference is how i populate the fields in terraform. I'm just pointing to some variables defined in variables.tf
Here they are:
variable "subnet_prefix_corp" {
    type = string
    default = "10.100.2.0/24"
variable "appliance_ip_corp" {
    type = string
    default = "10.100.2.1"
variable "subnet_prefix_iot" {
    type = string
    default = "10.110.2.0/24"
variable "appliance_ip_iot" {
    type = string
    default = "10.110.2.1"
variable "subnet_prefix_guest" {
    type = string
    default = "10.120.2.0/24"
variable "appliance_ip_guest" {
    type = string
    default = "10.120.2.1"
variable "subnet_prefix_mgmt" {
    type = string
    default = "10.130.2.0/24"
variable "appliance_ip_mgmt" {
    type = string
    default = "10.130.2.1"
It looks like Terraform is somehow re-ordering the array. But i'm not sure how or why 😕
MLL
Wrap your rules in a tolist() to force Terraform to treat it as an ordered list.
MartinLL
Thanks for the tip, but unfortunately it did not solve the issue.
rules wrapped in a tolist using locals:
locals {
  firewall_rules = tolist([
      dest_port      = "any"
      policy         = "deny"
      protocol       = "any"
      src_cidr       = "any"
      src_port       = "any"
      dest_cidr      = "any"
      dest_port      = "any"
      policy         = "allow"
      protocol       = "any"
      src_port       = "any"
      dest_cidr      = "any"
      dest_port      = "any"
      policy         = "allow"
      protocol       = "any"
      src_port       = "any"
      dest_cidr      = "any"
      dest_port      = "any"
      policy         = "allow"
      protocol       = "any"
      src_port       = "any"
  rules      = local.firewall_rules
Dashboard:
Copy of the state file block for firewall rules.
      "mode": "managed",
      "type": "meraki_networks_appliance_firewall_l3_firewall_rules",
      "name": "sb3_fw_l3",
      "provider": "provider[\"registry.terraform.io/cisco-open/meraki\"]",
      "instances": [
          "schema_version": 0,
          "attributes": {
            "network_id": "xxxxxxxxxx",
            "rules": [
                "dest_cidr": "any",
                "dest_port": "any",
                "policy": "allow",
                "protocol": "any",
                "src_cidr": "10.100.2.0/24",
                "src_port": "any",
                "syslog_enabled": false
                "dest_cidr": "any",
                "dest_port": "any",
                "policy": "allow",
                "protocol": "any",
                "src_cidr": "10.120.2.0/24",
                "src_port": "any",
                "dest_cidr": "any",
                "dest_port": "any",
                "policy": "allow",
                "protocol": "any",
                "src_cidr": "10.110.2.0/24",
                "src_port": "any",
                "dest_cidr": "10.0.0.0/8, 172.16.0.0/12, 192.168.0.0/16",
                "dest_port": "any",
                "policy": "deny",
                "protocol": "any",
                "src_cidr": "any",
                "src_port": "any",
            "rules_response": [
                "dest_cidr": "Any",
                "dest_port": "Any",
                "policy": "allow",
                "protocol": "any",
                "src_port": "Any",
                "dest_cidr": "Any",
                "dest_port": "Any",
                "policy": "allow",
                "protocol": "any",
                "src_port": "Any",
                "dest_cidr": "Any",
                "dest_port": "Any",
                "policy": "allow",
                "protocol": "any",
                "src_port": "Any",
                "dest_cidr": "Any",
                "dest_port": "Any",
                "policy": "allow",
                "protocol": "Any",
                "src_cidr": "Any",
                "src_port": "Any",
                "dest_cidr": "10.0.0.0/8,172.16.0.0/12,192.168.0.0/16",
                "dest_port": "Any",
                "policy": "deny",
                "protocol": "any",
                "src_cidr": "Any",
                "src_port": "Any",
            "syslog_default_rule": null
          "sensitive_attributes": [],
          "identity_schema_version": 0,
          "dependencies": [
            "meraki_networks.sb3"
The order in the statefile matches what i see in the dashboard. I just dont get why it reorders the array.
MLL
Oren
Oren
With the debug information, please.
MartinLL
Done. Here is a link to the issue.
Thanks for the replies 🙂
https://github.com/cisco-open/terraform-provider-meraki/issues/274
MLL
MartinLL
Fyi there is a commit do the dev branch of the repo with a possible solution now. 🙂
MLL
MartinLL
And now its merged with main. New provider version 1.1.7-beta is out 🙂
Thanks everyone!
MLL
Oren
Happy coding!
