Summary Report data via Python Module by SSID and with specific date period
peagacebe
I'd like to know if it's possible to get the data via Python that generates the graphs and tables in the Summary Report found in Organization -> Monitor -> Summary Report. Only by SSID and for a specific period, as is possible in the Meraki Dashboard. I saw that in /organizations/{organizationId}/summary/top/ it's possible to get some information but I was wondering if it's possible to separate each of the “top”s by SSID and get a specific period? And if so, how would you do that?
RaphaelL
This endpoint has a filter for SSIDs. Would that work ?
/organizations/{organizationId}/summary/top/applications/byUsage?ssidName="Name of the SSID"
7 Replies 7
The /organizations/{organizationId}/summary/top/ endpoint provides some aggregated data, you might need to use additional endpoints to filter by SSID and date period.
peagacebe
Please, do you have an example of a complementary endpoint to do this?
Unfortunately not. 😕
RaphaelL
Hi ,
Are you looking for https://developer.cisco.com/meraki/api-v1/get-organization-summary-top-ssids-by-usage/ ?
You can provide an SSID name and your t0,t1 timeframe.
peagacebe
Not exactly, for example I want to get “getOrganizationSummaryTopApplicationsByUsage” but divided by SSID
RaphaelL
peagacebe
I didn't know about this filter, I'll try it, thank you very much
