Splash Page
FHDENIT
Splash Page
I have some devices that I prefer to be on a Guest network, but the devices can't show a splash page.
Of course I can whitelist them, but then they have full access and fw rules are bypassed.
Can I by API approve the splash for the device ?
mlefebvre
Yes, you can use the endpoint I will list below to do that, but instead I would recommend making a Group Policy called BypassSplash or something similar, leave all the settings such as Firewall on Use Network Default, and just set the Splash setting to Bypass.
https://developer.cisco.com/meraki/api-v1/update-network-client-splash-authorization-status/
FHDENIT
I don't have that option since I'm not using Meraki APs but a third-party.
What is doing the splash page?  Meraki or third party solution?
FHDENIT
Meraki as pr. configuration at the Access Control for the VLAN:
