I guess it depends on how well you want to play with Meraki.
In the end Meraki is all about RESTful calls, whether it's the API or the Dashboard itself.
If you want to abide by the rules, then no, there isn't an endpoint to change the Splash Page Theme to Fluid.
But if you're feeling a bit rebelleous, there are ways around... Hint: cookies are delicious...
LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
