Setting device configuration - local credentials
CharlesMi
Is there a way to set the local password for a network via the API? I haven't been able to find an API call for this, but I wasn't sure if I was just missing it or if there currently isn't an option for this via API. We have over 2000 networks and deploying passwords one by one may be a bit more tedious than we'd like.
Ryan_Miles
5 Replies 5
Ryan_Miles
CharlesMi
Thank you so much for the quick response!
John_on_API
@Ryan_Miles you are on 🔥 today 👏🏽
John_on_API
@CharlesMi in a pinch you can also grep by keyword if you load up the openAPI spec: https://api.meraki.com/api/v1/openapiSpec
CharlesMi
@John_on_APIThat is awesome. I wasn't aware of that. Thank you very much! I'll look into this right now.
