Sensor data models misalignment for downStream power (latest/history)
david_n_m_bond
Hi Meraki devs.
There are two different models for "downstreamPower", depending on whether you call latest or history endpoints.  Please could this be fixed?
Latest returns:
                "ts": "2023-07-09T15:01:26Z",
                "metric": "downstreamPower",
                "downstreamPower": {
                    "override": "disabled",
                    "state": "enabled"
History returns:
            "locked": false,
            "enabled": true
Personally, I prefer the "history" version, as I believe these to be boolean CIs.
Author, https://www.nuget.org/packages/Meraki.Api/
KonJain
Hey @david_n_m_bond , we're rolling a fix out for this. Notifying here since its a breaking change and I can post what to expect. Both latest and historical will send the response in the following format:
                "ts": "2023-05-03T19:59:14Z",
                "metric": "remoteLockoutSwitch",
                "remoteLockoutSwitch": {
                    "locked": false
                    "enabled": true
 Note that for historical data, there will be extra info about the SN and Network ID in each objects.
This will be rolled out in a few days.
Let me know if you have any questions.
Thanks,
Konark
5 Replies 5
bryona
Hi @david_n_m_bond,
Thanks for posting in our Community forum.
Which API endpoint are you calling for each of these queries?
david_n_m_bond
Hi @david_n_m_bond ,
It looks like each API call should return [mostly] the same information, just that Latest returns a separate array for the actual metrics. If you're getting inconsistent readings for each, I'd open a support case to have this behavior validated and for our back-end team to address it.
John_on_API
Thanks for raising this @david_n_m_bond . This looks like a bug and if you'd like you can raise a support ticket to have it documented and prioritized.
KonJain
                    "locked": false
                    "enabled": true
Thanks,
Konark
