I'm trying to get the ports for router model MX67W using the API request:
https://api.meraki.com/api/v1/devices/{device_serial}/lldpCdp
as in the API documentation get-device-lldp-cdp but I'm getting an empty list of device ports.
Device lldpCdp:
While it is working in model MX67:
Device lldpCdp:
{'ports': {'wan1': {'cdp': {'sourcePort': 'wan1', 'deviceId': '3456fe2a6e44', 'address': '192.168.86.5', 'portId': 'Port 2'}, 'lldp': {'sourcePort': 'wan1', 'systemName': 'Meraki MS120-8 - Main Floor Living room Switch', 'managementAddress': '192.168.86.5', 'portId': '2'}}, 'port3': {'cdp': {'sourcePort': 'port3', 'deviceId': '3456fe2a6e44', 'address': '192.168.86.5', 'portId': 'Port 1'}, 'lldp': {'sourcePort': 'port3', 'systemName': 'Meraki MS120-8 - Main Floor Living room Switch', 'managementAddress': '192.168.86.5', 'portId': '1'}}, 'port4': {'cdp': {'sourcePort': 'port4', 'deviceId': '3456fec81bbe', 'address': '192.168.86.15', 'portId': 'Port 0'}, 'lldp': {'sourcePort': 'port4', 'systemName': 'Meraki MR74 - Back Yard', 'portId': '0'}}, 'port5': {'cdp': {'sourcePort': 'port5', 'deviceId': 'a8469d1bc422', 'address': '192.168.86.11', 'portId': 'Port 0'}, 'lldp': {'sourcePort': 'port5', 'systemName': 'Meraki MR56 - LivingRoomnew', 'portId': '0'}}}, 'sourceMac': 'ac:17:c8:bb:b2:a4'}
Could you please advise what should I do to make it work?
And you have confirmed ( with packet captures ) that you have devices sourcing LLDP/CDP packets on your MX67W ?
If so , I would suggest opening a ticket.
Also might be worth trying with the latest MX firmware version.
Hi RaphaelL,
Thank you for your reply, how do I know that I have devices sourcing LLDP/CDP packets on my MX67W from the packet captures log?
This is part of the MX67W packet captures log:
--- Start Of Stream ---
tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
listening on wan0_sniff, link-type EN10MB (Ethernet), snapshot length 262144 bytes
15:20:45.178699 IP 67.221.158.220 > 1.1.1.1: ICMP echo request, id 22530, seq 14699, length 64
15:20:45.178699 IP 67.221.158.220 > 8.8.8.8: ICMP echo request, id 22786, seq 14699, length 64
15:20:45.251074 IP 1.1.1.1 > 67.221.158.220: ICMP echo reply, id 22530, seq 14699, length 64
15:20:45.254601 IP 8.8.8.8 > 67.221.158.220: ICMP echo reply, id 22786, seq 14699, length 64
15:20:46.178699 IP 67.221.158.220 > 1.1.1.1: ICMP echo request, id 22530, seq 14700, length 64
15:20:46.178699 IP 67.221.158.220 > 8.8.8.8: ICMP echo request, id 22786, seq 14700, length 64
15:20:46.259967 IP 8.8.8.8 > 67.221.158.220: ICMP echo reply, id 22786, seq 14700, length 64
15:20:47.178699 IP 67.221.158.220 > 1.1.1.1: ICMP echo request, id 22530, seq 14701, length 64
15:20:47.178699 IP 67.221.158.220 > 8.8.8.8: ICMP echo request, id 22786, seq 14701, length 64
15:20:47.256263 IP 8.8.8.8 > 67.221.158.220: ICMP echo reply, id 22786, seq 14701, length 64
15:20:47.289867 IP 1.1.1.1 > 67.221.158.220: ICMP echo reply, id 22530, seq 14701, length 64
15:20:48.178699 IP 67.221.158.220 > 1.1.1.1: ICMP echo request, id 22530, seq 14702, length 64
15:20:48.178699 IP 67.221.158.220 > 8.8.8.8: ICMP echo request, id 22786, seq 14702, length 64
15:20:48.246359 IP 1.1.1.1 > 67.221.158.220: ICMP echo reply, id 22530, seq 14702, length 64
15:20:48.252682 IP 8.8.8.8 > 67.221.158.220: ICMP echo reply, id 22786, seq 14702, length 64
15:20:49.178699 IP 67.221.158.220 > 1.1.1.1: ICMP echo request, id 22530, seq 14703, length 64
15:20:49.178699 IP 67.221.158.220 > 8.8.8.8: ICMP echo request, id 22786, seq 14703, length 64
15:20:49.248849 IP 1.1.1.1 > 67.221.158.220: ICMP echo reply, id 22530, seq 14703, length 64
15:20:49.256052 IP 8.8.8.8 > 67.221.158.220: ICMP echo reply, id 22786, seq 14703, length 64
15:20:49.414394 IP 67.221.158.220.3111 > 8.8.8.8.443: Flags [S], seq 0, win 0, options [mss 536], length 0
15:20:49.414852 IP 67.221.158.217 > 67.221.158.220: ICMP time exceeded in-transit, length 52
Do you have any thoughts on why there are no CDP/LLDP packets being received?
What firmware are you using.
Make sure that you have devices sending cdp/lldp first.
it's MX 17.10.2
Is there any other api request that can return the port count and status, for each device?
