Rollout SSID to 50 networks in the same organization
ChrisSchu
Hey there,
i do need to rollout a new SSID to approx. 50 networks within the same org. Any recomandations? I am a python noob, used api a little bit before to get some network details but never used it for configure something. Thankful for any help.
cheers Chris
2 Replies 2
I'm going to guess these 50 networks are not bound to a template otherwise this would be easy.
I don't have anything directly to help.
Maybe check out the Meraki Python tutorial.
https://developer.cisco.com/meraki/
This GitHub has a lot of automation scripts.  Nothing that matches exactly what you want, but there are some scripts with interact with SSIDs, so something you could copy and paste.
https://github.com/meraki/automation-scripts
ChrisSchu
thanks, i managed to do it with meraki-cli https://github.com/PackeTsar/meraki-cli/blob/master/COMMAND_GUIDE.md with the following command:
meraki wireless updateNetworkWirelessSsid --organizationId XXXXXX --networkId 'N_XXXXXXXXXXXXXX' --number '14' --name 'XXXXXXXXXX' --enabled "true" --authMode 'psk' --encryptionMode 'wpa' --psk 'XXXXXXXX' --wpaEncryptionMode 'WPA2 only' --ipAssignmentMode 'Bridge mode' --useVlanTagging "true" --defaultVlanId "XXX" --visible "false"
I just copied this command in notepad and replayed the network-Id with the real ones and pasted all in the CLI. completed successfull to 130 networks even i guess there is a smarter solution with loops. overall i did in approx. 2 hours, by hand it would be 10hours (ish)
