Rest api, create new org admin, read only without network and tags
woonder2020
Dear all,
i want to create a new organisation admin by using  rest api,
user read only without network and tags,
but i get an http error 400 every time, if the tag is empty
example from cisco:
{ "id": "212406", "name": "Miles Meraki",
"email": "miles@meraki.com",
"orgAccess": "none", "accountStatus": "ok",
"twoFactorAuthEnabled": false,
"hasApiKey": true,
"lastActive": "2019-01-28 14:58:56 -0800",
   >>>>    "tags": [ { "tag": "west", "access": "read-only" } ],    <<<<<<
"networks": [ { "id": "N_24329156", "access": "full" }
Is this even possible ?
greetings ob
5 Replies 5
What does your request look like?
we use Servicenow and the rest api within Servicenow,
here is the body of a message:
"name":"billy test",
"email": "billy.test@testdomain.com",
"orgAccess":"read-only",
"tags": [{ "tag": "[]", "access": "read-only" }]
httpStatus: 201
responseBody: "{\"id\":\"1234976994152198008\",\"name\":\"Billy Test\",\"email\":\"billy.test@testdomain.com\",\"authenticationMethod\":\"Email\",\"orgAccess\":\"read-only\",\"accountStatus\":\"unverified\",\"twoFactorAuthEnabled\":false,\"hasApiKey\":false,\"lastActive\":\"\",\"networks\":[],\"tags\":[{\"tag\":\"[]\",\"access\":\"read-only\"}]}"
User Billy Test has been created successfully
This works, but i have these 2 sqaure brackets in the dashboard after creation of the account,
if the code looks like this:
"tags": [{ "tag": "", "access": "read-only" }]
i will get error 400 and the new adminwas not created
Try changing from:
to:
Using JSONlint.com can help identify issues.
	"name": "billy test",
	"orgAccess": "read-only",
	"tags": [{
		"tag": "[]",
Did you intend to try to tag the user with a tag that is simply square brackets?
How's it go if you leave out the tags param entirely? Only email, name and orgAccess are required.
Hi everbody,
i tried all your tips before, but everytime i will got the error 400,
but i found a workaround;
 i deleted tags complety in the content, now it works with the message 201 and the result in the dashboard is as excepted.
thank you for your help,
greetings
