Replacement Call for Organization Device Status ?
Craieggg
Hi all,
Going through a refresh internally of all our APi calls and I can now see that Get Organization Devices Statuses - Meraki Dashboard API v1 - Cisco Meraki Developer Hub has been marked as depreciated?
Is there any other call that provides the device status - online/offline?
Get Organization Devices - Meraki Dashboard API v1 - Cisco Meraki Developer Hub and Get Device - Meraki Dashboard API v1 - Cisco Meraki Developer Hub dont seem to give the status of the device.
Am I missing something completely obvious?
Oren
Meraki Employee All-Star
Most likely, device availabilities in the relevant successor, but check our deprecation page: https://developer.cisco.com/meraki/api-v1/deprecated-operations/#deprecated-operations.
We will have the deprecation banner refer to this page for easier discoverability.
I hope this helps.
2 Replies 2
Oren
I hope this helps.
Craieggg
Thank you @Oren , thats exactly what I was looking for!
Yes, it will be highly beneficial for depreciated calls to be related to the relevant call or notice that has replaced it. Would make user experience easy as well!
