I would like to be able to use the API to determine organization devices that have an upgrade status that matches with what the GUI portal shows as 'Ignore' (Within Organization-Wide > Settings)
Currently I can't seem to find a way to either directly do this via the API, or figure out the data endpoints that the GUI portal is using to make that determination. I wondered if anybody could assist.
Thank you.
