Power Supplies state
dbarr_pxo
Hello everyone,
Is it possible to get the power supply information for Mx64, Ms120?
I lookup in Dashboard API, but apparently they don't have any api for this purposes.
Thanks.
GreenMan
Meraki Alumni (Retired)
I'm assuming you are looking to understand the overall power consumption by the devices - as opposed to just that consumed by downstream PoE devices?   If so, we don't currently have the ability to make that directly available - though it's something we're working on - no timescale available on anything currently though.    Right now the best bet would be to use MT40 IoT sensors, which would provide a wealth of detail around consumption by the attached device(s)    It would also allow you to remotely power it / them off and on as needed - just be careful not to disrupt the connectivity to the gateway itself!
https://meraki.cisco.com/en-uk/product/sensors/indoor-sensors/mt40/
sungod
I think you can only get PSU status from devices that have swappable PSU modules like the larger MR and MX devices.
This gets it for you org-wide...
https://developer.cisco.com/meraki/api-v1/get-organization-devices-power-modules-statuses-by-device/
But it's not in-depth details.
GreenMan
dbarr_pxo
Thanks.
