Pagination not working for: GetOrganizationPolicyObjects API
Ilya_Kisel
Hi Meraki developers,
I noticed that API GET: /organizations/{organizationId}/policyObjects?perPage=100 response header "Link" is always empty.
I have 200 policy objects. Via paginated request I can receive only the first N (for example 100) entries, "Link" response header is empty and I consider that there are no more objects.
Request: curl -L --request GET \
--url https://api.meraki.com/api/v1/organizations/xxx/policyObjects?perPage=100 \
--header 'Authorization: Bearer xxx' \
--header 'Accept: application/json'
RaphaelL
Hi ,
This has been reported multiple times here and on reddit. I would suggest you to open a case.
Ryan_Miles
@RaphaelL is correct and I see an internal bug filed on this already. As suggested I would open a case so they can attach yours to the parent case/bug and hopefully it will add add some traction to getting this resolved.
Ryan
Ilya_Kisel
Hi @Ryan_Miles, do you have an estimation of when the fix will be ready?
Hi @Ilya_Kisel
Progress tracking and updates would need to come from Meraki Support. If you haven't already please open a Support case and they can link your issue to the parent issue for tracking & updates.
Cheers
Ryan
