PUT /devices/{serial} endpoint giving a 500 error if "address" is specified in JSON body
mwmatter
I am seeing issues with the specified endpoint giving a 500 error if you try to pass a value in to the address option in the JSON body. Example request body
"name": "MY DEVICE",
"serial": "SERIAL-HERE",
"tags": [ "TEST", "TEST123" ],
"address": "Some Address Here",
"moveMapMarker": true
Anyone else seeing this or can reproduce this?
mwmatter
This was resolved by Meraki support.
3 REPLIES 3
Is the address accepted in the dashboard?
Good thinking. So looks like the issue is actually related to taking the address and getting long/lat for the given address. If you enter in an address and have the "Move Marker" checked it fails with a message of "Geocoding failed". If you turn off the "Move Marker" it saves the address.
So seems like the actual issue is whatever service or logic the geocoding uses is not working. I tried 5 different addresses with different syntax and nothing will save.
mwmatter
