Organization Webhook Payload Templates and Http Servers - UI missing, assignment not working
david_n_m_bond
I can create, update and delete Organization-level (as opposed to Network-level) Webhook Payload Templates and corresponding HTTP Servers.
Two critical issues:
  1. There seems to be no UI for these at the organization level, despite a links that claims to go to "Configure organization-wide alerts at Organization > Settings" on the Network's Alert Settings page.
  2. When assigning Http Servers to the network, no error is returned, but assignment fails and a subsequent fetch of a network's alert settings yields no HttpServers
  3. I am not receiving any alerts at the HTTP Server
Is this functionality working AT ALL, or is the advice "use per-network PayloadTemplates and HttpServers for now"?
Author, https://www.nuget.org/packages/Meraki.Api/
Ryan_Miles
If you're talking about this webhook endpoint https://developer.cisco.com/meraki/api-v1/get-organization-webhooks-http-servers/ it only pertains to Meraki Insight.
Standard webhook templates are network level only today.
Ryan / SE - Networking
2 Replies 2
Ryan_Miles
Thanks @Ryan_Miles - that explains a lot!
I was hoping that I could define:
  • a single Webhook Template
  • a single HTTP Server
...and assign these to all networks' alert settings.
Instead, we have to create thousands of identical duplicates for each network.
It seems odd, because the "out of the box" templates ARE centralised, (Microsoft Teams, for example).  Surely it would make sense to allow the organization-level webhook templates to be used?  This would involve no UI change other than extending the list dropdown.
Similarly, it would make sense to permit users to use centralised HTTP Servers, to avoid having to re-enter credentials every time a network is added.
