Meraki Node-RED node
DexterLaBora
Introducing the Meraki Node-RED node!
A custom built add-on to easily drag & drop your way to network automation.
Blog
https://meraki.cisco.com/blog/2019/10/take-the-work-out-of-programming/
Docs
https://developer.cisco.com/docs/meraki-dashboard-api-node-red-node/
Install the node and list your organizations in under 30 seconds
Then, build a custom Dashboard using the Node-RED UI nodes.
4 REPLIES 4
BlakeRichardson
Re: Meraki Node-RED node
Looks good, I really do need to start playing around with the API
Nash
@BlakeRichardson Join ussssss the water is warm and only a little full of snakes!
What about the spiders?
LukeSwinbourne
This API integration with Node-RED looks awesome and something I will be testing out on my lab once it's all set-up!
