Hello Guys
Is there any API which can create meraki switch template and bind it to meraki switch. i m able to find GET and Put APIs for meraki switch template.
if you can share API it will be very helpful.
Regards
Deepak Rauthan
Have you checked the API documentation? There you will find all available APIs.
https://developer.cisco.com/meraki/api-v1/create-organization-config-template/
https://developer.cisco.com/meraki/api-v1/bind-network/
