List all wireless access points from a network
vitormariano
Hi, there!
Is there any way to just list the wireless access points from a network, and count the devices connected to each of them? I noticed that the endpoint for listing devices doesn't specify which device type.
Hi, you basically have to make it work yourself using code.
For example:
response = dashboard.networks.getNetworkDevices(
network_id
for item in response:
if (item["model"]).startswith("MR"):
print (item)
Ryan_Miles
Are you specifically looking for an API way to do this? If not you can also get the info from the client summary page by filtering on wireless clients, enabled the connected to column, and then export to csv.
vitormariano
Yes, my goal is to track the number of connected devices on each access point via API.
