Hello folks,
In our dashboard API authorization docs we name the base URIs (e.g. https://api.meraki.com/api/v1 for US Commercial) to use when making API requests. These are the only base URIs that should be used for dashboard API requests. Making API requests to undocumented base URIs can mean your application suddenly stops working, the fix for which would be to change your base URL to one that's documented for your region.
Call to action: developers
If you have developed and/or maintain an integration that uses dashboard API, please ensure you're using only the documented base URI for your region. If you already only use the documented base URI(s), then no action is required.
Call to action: non-developer users or consumers of integrations
If you leverage integrations but are not involved in the development, please check with your integration's developer that they are only using the documented base URI for your region. They should be able to affirm which base URI(s) they are using and affirm whether or not they are documented in our docs page, as well as advise on a remediation plan.
