I need to update the dot11r settings for my network.
The code I used to update the settings are:
response = dashboard.wireless.updateNetworkWirelessSsid(
n['id'], ssid['number'],
ssid['dot11r']= {'enabled': True, 'adaptive': True}
Python error message is
Traceback (most recent call last):
File "/home/user/updatessid.py", line 31, in <module>
TypeError: Wireless.updateNetworkWirelessSsid() takes 3 positional arguments but 4 were given
I tried to follow the example here
https://developer.cisco.com/meraki/api-v1/#!update-network-wireless-ssid
response = dashboard.wireless.updateNetworkWirelessSsid( network_id, number, name='My SSID', enabled=True )
What is the correct way to update the dot11r settings?
Solved! Go to Solution.
import requests url = "https://api.meraki.com/api/v1/networks/{networkId}/wireless/ssids/{number}" payload = '''{ "dot11w": {}, "dot11r": { "adaptive": true }, "oauth": {}, "localRadius": { "passwordAuthentication": {}, "certificateAuthentication": { "clientRootCaCertificate": {} } },
I think that there is no PAI to update 802.11, look:
https://developer.cisco.com/meraki/api/#!update-network-ssid
Sorry I'm worng:
what's different between your link and mine?
Not supported?
the first link is API v0 second Is v1.
I tried again with new code.
dot11r=[{'enabled': True, 'adaptive': True}]
Here is what I got.
meraki.exceptions.APIError: wireless, updateNetworkWirelessSsid - 400 Bad Request, {'errors': ["'dot11r' must be an object"]}
Thank you!
Got it workinig with following code.
dot11r={'enabled': True, 'adaptive': True}
Thank you!
