How to get Top blocked sites by URL using API
azrul6
Hi
Currently i already manage to fetch contentfiltering from each network in my orgnanization using this 2 call
https://api.meraki.com/api/v1/organizations/{organizationId}/networks
https://api.meraki.com/api/v1/networks/{networkId}/appliance/contentFiltering
I already go through the api documentation , but still can't find how to get blocked sites data. It can be done by report summary in meraki dashboard but how i want to achieve this using API ?
Can anyone help me or give some tips how to fetch the data.
thanks
sungod
For reporting, the ones I use to get security/blocking related events are...
https://developer.cisco.com/meraki/api-v1/get-network-events/    with filters to select just the event types I want, for instance...
aiomeraki.networks.getNetworkEvents(net['id'], productType="appliance", includedEventTypes = ["nbar_block", "cf_block", "sf_url_block", "sf_binary_block"], perPage=1000, total_pages="all")
See this for the current list of event types... https://developer.cisco.com/meraki/api-v1/get-network-events-event-types/
...note that the return format/content varies depending on event type, I don't think it's definitively documented, I ended up gathering lots of events to work out the format of the ones I was interested in, there can also be different formats for the same event type.
But not all events are 'events' 😀 This call is also needed...
https://developer.cisco.com/meraki/api-v1/get-organization-appliance-security-events/
....there's a network-level version of this too...
https://developer.cisco.com/meraki/api-v1/get-network-appliance-security-events/
I actually prefer the network-level version, as the org-level one doesn't include the network ID in responses (which IMO it should!)
5 Replies 5
sungod
azrul6
Thanks for your guide, already make the progress in this matter.. manage to fetch the data either from organization or network..
but i got on more problem,
from the dashboard it self.. it can show report from 1st september but using the api
response = dashboard.appliance.getNetworkApplianceSecurityEvents  or
response = dashboard.appliance.getOrganizationApplianceSecurityEvents
already set t0=1725148800
my result will only show from 5th of september not from 1st septem.. i wonder where the problem because i already using same timestamp for other api, it show correctly from 1st september
thanks for your help
sungod
Can you post all the parameters you are using, not only the t0 value.
Are you 100% certain there were security events between 1st and 5th? Remember some events related to security are actually obtained as network events.
If you set t0 to 1696982400 (about a year ago) what do you see?
azrul6
This is all the parameter
response = dashboard.appliance.getOrganizationApplianceSecurityEvents(
organization_id,
total_pages='all',
perPage='1000',
t0=starting_after,
t1=ending_before
where  starting_after=1725148800 and ending_before = 1727740799
Already set t0 to 1696982400, same result only manage to fetch data from 5th september
sungod
You have...
perPage='1000',
...but this should be an integer, try...
perPage=1000,
Otherwise, assuming the equipment has been installed and with current config before 1st September, if there were security events they should be there.
One other thing to try, just in case something weird is going on, add the parameter...
sortOrder='descending'
...and see if it makes a difference to what you get.
If it's still not working, you may need to open a support case.
