- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
How to call getNetworkDeviceManagementInterfaceSettings()
I'm getting my feet wet on new Meraki SDK. I'm having trouble understanding how to call different functions from this link.
What is the logic for e.g. function getNetworkDeviceManagementInterfaceSettings()?
import meraki
api_key = '<api_key>'
m = meraki.DashboardAPI(api_key)
orgs = m.organizations.getOrganizations()
org_id = orgs[0]['id']
#get Networks
nets = m.networks.getOrganizationNetworks
#how to call getNetworkDeviceManagementInterfaceSettings()?
m.networks.getOrganizationNetworks('<network_id>').getNetworkDeviceManagementInterfaceSettings()#?
Regards
Solved! Go to solution.
- Labels:
Code Sample
Dashboard API
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It's a little bit tricky.
you need to know the network and the serial of each device in the network
import meraki
api_key = "<api_key>"
org_id = orgs[0]["id"]
#get Networks
networks = m.networks.getOrganizationNetworks(org_id)
#iterate through all the networks in the organization
for net in networks:
devices = m.devices.getNetworkDevices(net["id"])
#iterate through all the devices in the network
for d in devices:
#extract the management interface setting for each device
settings = m.management_interface_settings.getNetworkDeviceManagementInterfaceSettings(net["id"],d["serial"])
print(settings)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
import meraki
#get Networks
for d in devices:
print(settings)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I tried to use different function from that class to update mgmt interface, but It doesn't work for me. What am I doing wrong? How can I update interface WAN2?
below is just a portion of code.
data = {'wan1': {'wanEnabled': 'not configured', 'usingStaticIp': False, 'vlan': None}, 'wan2': {'wanEnabled': 'not configured','usingStaticIp': True,'staticIp': '1.1.1.1','staticSubnetMask': '255.255.255.252','staticGatewayIp': '1.1.1.2.','staticDns': [ '8.8.8.8', '8.8.8.8.']} 'vlan': None}}
settings = m.management_interface_settings.getNetworkDeviceManagementInterfaceSettings(networkID,mx_serial_number, data)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
every method which starts with "get" will read the data from the dashboard. You won't be able to update the settings with this.
In your case you will need updateNetworkDeviceManagementInterfaceSettings
def updateNetworkDeviceManagementInterfaceSettings(self, networkId: str, serial: str, **kwargs):
**Update the management interface settings for a device**
https://api.meraki.com/api_docs#update-the-management-interface-settings-for-a-device
- networkId (string)
- serial (string)
- wan1 (object): WAN 1 settings
- wan2 (object): WAN 2 settings (only for MX devices)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
sry it was a typo, I meant updateNetworkDeviceManagementInterfaceSettings() but how to passe arguments for wan2 link?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I haven't tried it, but from the docs it should work like that:
data_wan1 = {'wanEnabled': 'not configured', 'usingStaticIp': False, 'vlan': None}
data_wan2 = {'wanEnabled': 'not configured','usingStaticIp': True,'staticIp': '1.1.1.1','staticSubnetMask': '255.255.255.252','staticGatewayIp': '1.1.1.2.','staticDns': [ '8.8.8.8', '8.8.8.8.']} 'vlan': None}
m.management_interface_settings.updateNetworkDeviceManagementInterfaceSettings(networkID,mx_serial_number, wan1=data_wan1, wan2=data_wan2)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you!
