How to apply SSID configuration to multiple networks at once using API / Postman
Madcoms
Hello Community,
I’m currently working with a customer who has more than 100 networks (offices) in their Meraki organization. The goal is to create or update the same SSID configuration across all networks in bulk.
Right now, I’m using Postman with the Meraki API and I can apply the configuration to one network at a time by specifying the networkId and the SSID number.
The problem:
Postman only applies the request to one network at a time.
I tried adding multiple networkIds in the same request body, but the API only accepts a single networkId.
For a large customer with many networks, this is not efficient.
My questions are:
Is there a supported way to apply SSID configuration to multiple networks at once using the API?
Is Postman Runner with CSV the recommended method, or is there a better approach (Python SDK, automation scripts, etc.)?
Can the configuration of an SSID be exported from one network and imported into others in bulk?
Any advice, examples, or best practices for handling large-scale deployments would be very helpful.
Thanks in advance!
5 Replies 5
You can use configuration sync.
https://documentation.meraki.com/General_Administration/Organizations_and_Networks/Cloning_Networks_...
Note that configuration sync only works when you don't have "combined" networks (which are used by most people).  It only works if the network is "WiFi" only.
Another suggestion would be to use templates, which would allow you to change settings simultaneously. This would be more efficient than using APIs.
https://documentation.meraki.com/General_Administration/Templates_and_Config_Sync/Managing_Multiple_...
Yes.  You will need to use the Python SDK.
I'm unable to share a complete working example, but I've included a code snippet using the asyncio library.  What I did for this customer was have them create a dummy network with the SSID configuration they wanted, and then this script copied those SSID settings from that network to every other network.
This way, they could make future changes to the SSID and reuse the same script.
	try:
		if commit:
			# Let everyone know what we are going to process
			for toNet in mxNetworks:
				log.info(f"Enqueing '{toNet['name']}' for processing")
			# Build the SSID argument list
			kwargs = {}
			for setting in ssidSettings:
				kwargs[setting]=ssidSettings[setting]
			# Now concurrently process all of the MR networks
			clientTasks=[dashboard.appliance.updateNetworkApplianceSsid(toNet['id'],**kwargs) for toNet in mxNetworks]
			for task in asyncio.as_completed(clientTasks):
					await task
Gracie-Mae
You can’t push to all at once. The best way is looping through network IDs with Postman Runner or a Python script
