Get words in a [ ] in separate words
Tbells
I am trying to get words in a [ ] to be generated in separate words.  I have a list of tags in a [] which the python sees as an array which is no.
Examples are shown below
"tags": [
                "FileZilla",
                "London",
                "NUC"
"tags": [
                "Laptop",
                "Stockholm"
"tags": [
                "Corporate_Apps",
                "Jabber",
                "London",
                "Okta",
                "VBDevice",
                "exchage2",
                "iPhone",
                "mobile"
Above are the tags for each device in the organisation. I will the tags to come as
Corporate_Apps,
                Jabber,
                London,
                Okta,
                VBDevice,
                exchage2,
                iPhone,
                mobile
for each tag as am trying to export it into a SQL table other columns work perfectly but just tags seem not to work while generating it from the API using python into a database. I have tried using split but that doesn't seem to work.
However am really need to Python, please be nice.
Thank you all.
5 REPLIES 5
BrechtSchamp
Re: Get words in a [ ] in separate words
How are you calling the API? I ask because generally when I've seen tags be returned, they've been a single string with tags separated by a space.
In that case to turn them into an array you can simply do:
array_of_tags = your_string_containing_the_tags.split(' ')
It may help if you share some of your code (take out any sensitive information).
Tbells
@BrechtSchamp Thanks for your response, really appreciate
import json
import pandas as pd
import sqlalchemy
import pyodbc
#file = open('rhapitest.json')
import requests
url = "###########/"
querystring = {"fields":["phoneNumber","location","lastConnected"]}
headers = {
'x-cisco-meraki-api-key': "##########",
'content-type': "application/json",
'accept': "application/json",
'cache-control': "no-cache",
'postman-token': "###########"
response = requests.request("GET", url, headers=headers, params=querystring)
data = json.loads(response.text)
#print(data)
id,name,tags,osName,systemModel,serialNumber,lastConnected,location = [],[],[],[],[],[],[],[]
#x = 0
for device in data['devices']:
# x = x+1
# print (x)
id.append(device[u'id'])
name.append(device[u'name'])
temp1=(device[u'tags'])
if not temp1:
tags.append("No tags available")
else:
', '.join(temp1)
print(temp1)
# try:
# mylist = (device[u'tags'])
# except:
# tags.append("No tag available")
# else:
# str(mylist).strip('[]')
osName.append(device[u'osName'])
systemModel.append(device[u'systemModel'])
serialNumber.append(device[u'serialNumber'])
lastConnected.append(device[u'lastConnected'])
#location.append(device['location'])
try:
temp=device[u'location']
except:
location.append("No location")
else:
location.append(device[u'location'])
#print(temp)
#if (device[u'location']) in data:
# print(device[u'location'])
df = pd.DataFrame([id,name,tags,osName,systemModel,serialNumber,lastConnected,location]).T
#df = df.apply(lamba location: location.str.replace(',',' ',))
#df = df.replace(',',' ', regex=True)
#df['location'] = df['location'].replace('[',' ', regex=True)
#df['location'] = df['location'].replace(']',' ', regex=True)
df.columns = ['id','name','tags','osName','systemModel','serialNumber','lastConnected','location']
#print(data)
#df.to_csv('output.csv',
#sep=',', encoding =
#'utf-8', index=False)
connStr = pyodbc.connect(
"DRIVER={SQL Server};"
"SERVER=#######;"
"Database=#####;"
#"Trusted_Connection=yes;"
"UID=ciphrconnector;"
"PWD=#######"
cursor = connStr.cursor()
for index,row in df.iterrows():
cursor.execute("INSERT INTO dbo.Meraki_Staging_API([MID],[name],[tags],[osName],[systemModel],[serialNumber],[lastConnected],[location]) values (?,?,?,?,?,?,?,?)", row['id'],row['name'],row['tags'],row['osName'],row['systemModel'],row['serialNumber'],row['lastConnected'],row['location'])
connStr.commit()
cursor.close()
connStr.close()
That is an example of my code. the column with the issue is tags, at the moment the data in the tags columns shows like this
"tags": [
                "Corporate_Apps",
                "Jabber",
                "London",
                "Okta",
                "VBDevice",
                "exchage2",
                "iPhone",
                "mobile"
"tags": [
                "Laptop",
                "OwnCloud",
                "Shanghai"
So am guessing is not going into the database because of the [] and "" around the list of words in it. At the moment the if statement works but only pulls in the No tags available into the DB tables but not other tags.
I hope this helps
BrechtSchamp
Okay, without debugging the code, does this help you:
import json
import requests
url = "h t t p s ://api.meraki.com/api/v0/networks/XXXXXXXXXXXXXXX/sm/devices"
headers = {
    'Accept': "*/*",
    'X-Cisco-Meraki-API-Key': "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXx",
    'Cache-Control': "no-cache",
    'Accept-Encoding': "gzip, deflate",
    'Connection': "keep-alive",
response = requests.request("GET", url, headers=headers)
print(response.text)
result = json.loads(response.text)
for device in result["devices"]:
    print("- DEVICE NAME:", device["name"])
    #device["tags"] is an array containing the tags of a device
    #if you just want a comma separated string of tags
    print(" * comma-separated string of tags:")
    print(','.join(device["tags"]))
    #if you want to go over all tags of a device
    print(" * iterating over the tags")
    for tag in device["tags"]:
        print(tag)
    print("---------------------")
Tbells
Thank you and will try this.
Tbells
import JSON
import pandas as PD
import sqlalchemy
import pyodbc
import requests
url = "https://n142.meraki.com/########”
headers = {
    'x-cisco-meraki-api-key': "#####",
    'postman-token': "#######"
#print(data)
id,name,strTags,osName,systemModel,serialNumber,lastConnected,location = [],[],[],[],[],[],[],[]
#x = 0
  #  x = x+1
   # print (x)
   # tags.append(device[u'tags'])
    #print (device[u'name'])
    #print (device[u'tags'])
    if temp1:
     temp2 = ','.join(temp1)
     strTags.append(temp2)
      #strTags.append=(device[u"tags"])
    if not temp1:
     strTags.append("")
      #  (device[u'tags'])
      #  tags = (device[u'tags'])
    #print(tags[x])
    #    print (2)
    #print (temp1)
    # print (tags)
     #  try:
   #    temp1=device[u'tags']
    #except:
    #else:
    try:
    except:
    else:
    #print(temp)
df = pd.DataFrame([id,name,strTags,osName,systemModel,serialNumber,lastConnected,location]).T
#print(data)
   "SERVER=####;"
   "Database=#####;"
   "UID=#####;"
   "PWD={#######}"
  cursor.execute("INSERT INTO dbo.Meraki_Staging_API([MID],[name],[tags],[osName],[systemModel],[serialNumber],[lastConnected],[location]) values (?,?,?,?,?,?,?,?)", row['id'],row['name'],str(strTags),row['osName'],row['systemModel'],row['serialNumber'],row['lastConnected'],row['location'])
  connStr.commit()
cursor.close()
connStr.close()
Everything works apart from the fact that the tags column data for each column shows as
    "tags": [
    "NUC",
    "Sydney"
    "tags": [
    "FileZilla",
    "London",
    "NUC"
    However, I will like it to show
    MID   name     tags       ssid        wifiMac osName               systemModel      uuid       serialNumber               hasChromeMdm
    642    B050949              ['NUC,Sydney']   NULL     NULL     Windows 8.1 Enterprise
    644    NYCDC01             ['FileZilla,London,NUC']  NULL     NULL     Windows Server 2012 R2 (64-
I want the program to work in a way whereby all the tags for each MID are not in one column but tags
    each MID should be shown at each column instead.  Your help will be really helpful as I am new to writing python and API.  The issues am having now is that all the tags are showing on each column instead of showing the tags linked to each MID in the SQL table
I hope this more clear.
Thank you so much for the help
