Get Device Loss And Latency History Empty Response
MediWat
I am attempting to collect data from the API call 'getDeviceLossAndLatencyHistory', specifically the "losspercent" response.  I have tried making the call via Python (script below) and directly on the Meraki Devnet portal (Cisco Meraki - Create with the Meraki Platform)  but the response is [] for both methods.  All of the other calls that I have tried return the expected data, just this one gives the empty response.  I have tried using different network ID, Serial, and IP sets.  I have also tried entering different timespan and resolution parameters with the same result.  There are a couple of other articles listed here, but they didn't seem to have pertinent answers.  If anyone can assist with this it would be greatly appreciated.
import requests
import json
BASE_URL = 'https://api.meraki.com/api/v1'
headers = { 'X-Cisco-Meraki-API-Key': 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' }
RESOURCE = '/organizations'
call_response = requests.get('https://api.meraki.com/api/v1/networks/L_xxxxxxxxxxxxxxxx/devices/XXXX-XXXX-XXXX/lossAndLatencyHisto...', headers = headers)
parsed_response = json.loads(call_response.text)
print(parsed_response)
RaphaelL
Just tried it and works like a charm !
Are you sure that the provided ip=X.X.X.X has been configured on your MX ? ( SD-WAN & Trafic shaping ) :
RaphaelL
sungod
You need to specify the destination IP, it's mandatory.
For instance, if I get the details for a few minutes for WAN 1 on an MX that is set to use 8.8.8.8 for it's latency reporting, with query parameters...
timespan 1200, resolution 60, interface wan1, ip 8.8.8.8
I get...
"startTs": "2022-05-31T12:48:00Z",
"endTs": "2022-05-31T12:49:00Z",
"lossPercent": null,
"latencyMs": null,
"goodput": null,
"jitter": null
"startTs": "2022-05-31T12:49:00Z",
"endTs": "2022-05-31T12:50:00Z",
"lossPercent": 0,
"latencyMs": 13.96,
"goodput": 100000,
"jitter": 0.35
"startTs": "2022-05-31T12:50:00Z",
"endTs": "2022-05-31T12:51:00Z",
"lossPercent": 0,
"latencyMs": 13.92,
"goodput": 100000,
"jitter": 0.38
"startTs": "2022-05-31T12:51:00Z",
"endTs": "2022-05-31T12:52:00Z",
"lossPercent": 0,
"latencyMs": 13.95,
"goodput": 100000,
"jitter": 0.34
"startTs": "2022-05-31T12:52:00Z",
"endTs": "2022-05-31T12:53:00Z",
"lossPercent": 0,
"latencyMs": 14.04,
"goodput": 100000,
"jitter": 0.53
"startTs": "2022-05-31T12:53:00Z",
"endTs": "2022-05-31T12:54:00Z",
"lossPercent": 0,
"latencyMs": 13.9,
"goodput": 100000,
"jitter": 0.28
"startTs": "2022-05-31T12:54:00Z",
"endTs": "2022-05-31T12:55:00Z",
"lossPercent": 0,
"latencyMs": 13.87,
"goodput": 100000,
"jitter": 0.35
"startTs": "2022-05-31T12:55:00Z",
"endTs": "2022-05-31T12:56:00Z",
"lossPercent": 0,
"latencyMs": 13.91,
"goodput": 100000,
"jitter": 0.21
"startTs": "2022-05-31T12:56:00Z",
"endTs": "2022-05-31T12:57:00Z",
"lossPercent": 0,
"latencyMs": 13.85,
"goodput": 100000,
"jitter": 0.29
"startTs": "2022-05-31T12:57:00Z",
"endTs": "2022-05-31T12:58:00Z",
"lossPercent": 0,
"latencyMs": 13.94,
"goodput": 100000,
"jitter": 0.3
MediWat
Thank you for the quick repsonses!  This was the issue, I didn't undestand the IP parameter was for the uplink statistics destination, not for the public IP assigned to that WAN interface.  This is working for me now, thank very much!
